Doctorbass said:
Are you sure a PFC supply produce more heat?? :? It is more efficient and the meanwell use synchronous mosfet instead of rectifier wich decrease heat again more...
Please explain what you mean by saying that a PFC supply produce more heat... the RSP serie certainly does not!
Its an extra stage, so it will never have 100% efficiency, so you add the losses of both (step-up - PFC, and step-down - PSU) and you end up with a bigger number than you would have had you just had a single stage (step down).
Efficiency (ie. power in vs power out) of a PFC increases as its input voltage increases, but its
effectiveness (power factor) drops at the same time. Its bloody complicated, and basically means at 115V you can achieve 0.99, and 277V, 0.89. Due to the current in the inductor, your I2R losses in the inductor and highside/lowside mosfets are higher with a lower voltage and lower with a higher voltage (efficiency).
There is a long, complicated whitepaper explaining why, I read it and it made my head hurt, but it has something to do with being able to extract energy over a longer part of the cycle at lower voltages. Reading the graphs on their PFC supplies you will see this as well.
RSP is pretty efficient, especially if it has a synchronous rectifier on the PFC rather than a shottky diode (so I2R losses rather than VFI losses) - they are a high frequency converter and a full bridge if I remember correctly, so no need for core reset (and the attendent losses there as well).
Doctorbass said:
Those 2Kw BMSBattery chargers are (IIRC) 0.8 PF, which means you derate to 1.2 X output + efficiency losses.
For mine it's more like 0.7 to 0.8.. they dont have any real PFC.. i get about 1500W out for a 2000W in... until the breaker trip... lol.. ( so i readjusted teh current limit)
It also is a big deal for any industrial uses, where consumers DO pay KVAR and not just KWH.
In Canada, Home electrical meter do measure apparent power(KVAR). They assume that the PF of average use is high enough. The suggest that if the power factor is less than 0.9 for medium to low power demand or if it is less than 0.95 for higher power, customers can request teh install of a power factor corrector device at their cost and upon their approval.
Doc
Well I'll be darned
- domestic consumers being charged for KVAR? First time I have ever encountered this.
Is it measured or actually charged for? I know the PF of my house is abyssmal - switchmode PSU's and LED's, CFL's, motors - and the only heating elements are in the dishwasher and oven - PF is usually about 0.5-0.65 most days! I always wonder if I end up using more of the solar generation as a result though...
TL;DR - nice job, turned out well, RSP's are very nice supplies for the money, especially if you can get them for the price you did (they are three times the price here!).
