Cyclomania
So in this video I have my newly installed bbs02-motor on the crank. But before I put pedals and chain on here I wonder if this axle looks a bit to loose or if this is just normal.
When I yank on it it kind of moves a millimeter or so back and forth. I am not sure if this is normal and I can just go ride with this bike?
Or do I need to tighten something in here?
Perhaps the two axle nuts on the outer side of the bearings, inside the axle, needs to be even tighter? So perhaps I need to remove the visible oil seal there and kind of screw in the axle nuts even harder and more towards the middle?
Or is that not necessary?
