mike662
Hi everyone, this is my first post on here. I have built an ebike a couple of months ago and it has been serving me well. It is an aluminum bike I bought at Costco years ago and I installed a GoldenMotor 1000W 48V rear hub motor on it. So far the bike has been serving me well, but I want to install some torque arms on it. Before I take everything apart again, I have a few questions. Is there anything I should know about the do's and don'ts of installing a torque arm? I would especially like to know whether or not I need to have the torque washers installed on both sides of the dropouts? My idea is to have nut, torque arm, dropout, washer, washer (the extra washer is for helping the off-center hub) hub motor, gears, washer, dropout, torque arm, nut. The reason for this is because I don't have enough room to have all the washers and 2 torque arms on. Is it bad to have the torque arms directly in contact with the dropouts? Do the torque arms need to be perfectly aligned with the frame so that they hold the axle at a perfect perpendicular angle (meaning that when you look at the bike from the back, the torque arm isn't on an angle toward the left or the right of the bike, so that the arm is flat against the dropouts and frame)? Will constantly tightening and undoing and re-tightening the bolts on aluminum dropouts weaken the dropouts? Thanks! Here are a few pics:
