QuebecoisSti
100 µW
Hello guys,
It's been a long time since I did not came back.
Here's what I wanted to convert first, some time ago...: https://endless-sphere.com/forums/viewtopic.php?f=10&t=76146
I've done a long pause but now I want to make this project come to life!
Finally, it ended up doing a drag 2wd ATV instead. It is based from a Yamaha Blaster chassis. I wish to make it work this summer.
Actual specs:
Zilla Z1K-HV
Pimped DC motor coming from a forklift
CycleAnalyst HV option
Custom pack from Li-Po, 48s4p from 32x 6s1p RC style packs. They should be able to output around 100C.
Here's the schematic:
Right now, I am concerned about how to charge it:
First, I bought an adjustable DC power supply 0-150VDC/0-20A but since my pack configuration change, I can't use it now. However, the unit is stucked in Remote Mode and can't figure out how to switch to "manual mode"... I take a look in manual, look out for pins and fuse, can't see why it's staying in Remote.
The second idea I had was to hook every packs on a PowerLab 8x2 but since I can only do 12 at a time it is a little bit time consuming and packs would only be charge using balance connector which is slow.
I had Y-harness on all packs balance connector, I tried to connect to the balance board but it seems he doesn't like it... got fuse blown and short circuit look alike... I don't understand why it happens, everything is in parallel in a Y-harness, right ?? It should work ??
I got help from DoctorBass, he suggest me to buy a charger (TC Charger or similar) that would be set it according to my pack but I may change the configuration later or do something else so I don't really want to speed a thousand $ or so on something that may not be usable after.
The other idea was to buy another adjustable DC power supply, something around 0-220VDC to be versatile. Or maybe hook up a smaller one (0-60VDC) to mine 0-150VDC but I read it's not really a good idea to put power supply in series...
I sent a couple e-mail to some companies (Batrium, LTW Battery, EV-propulsion, Elithion, Ewertenergy) about if they sell a BMS using Li-Po balance connector but most of them were not or it was way too costly. I had this "BMS" system I got when I had the Li-Po packs but it seems pretty shitty and doesn't look to work all packs connected together.
In brief, TLDR:
- I wish to have a charger or a way to charge all 32packs at the same time with possibility to change parameter of charging if I change the pack configuration.
Thanks for your support,
Actual specs:
Zilla Z1K-HV
In brief, TLDR:
