Drainbrain calibration
Doctorbass
Quebec, Canada East
Does anyone know the calibration procedure for the drainbrain?
speed, shunt volt, etc? or already modify some of those? i'm talking most about the advanced parameter
I'm not familiar with many of these parameter:
Set Units :km
Set Wheel 2075mm
Max Speed 99kph
Max Amp 35A
Min Volt 20V
Main Display Watts
Zero amp
Set Rshunt 1.164mOHM
Advanced
Volt Sense 21.04V/V
PSGain 0.11V/kph
IntSGain 200
PAGain 0.07V/A
IntAgain 300
PVGain 0.38V/V
IntVGain 800
Iterm Max 3.49V
Iterm Min 0.49V
Max Throttle 4.98V
Set n Pole 12
Set Ratio 0.1023 LG/HG
Averaging 5
Set Range Low(.01A)
Have you figured it out yet ?
I'm going to dive into mine tonight, i received it 2 weeks ago and have only plugged it in to make sure it lights up... have not had time to adjust any settings yet..
Change your "NPoles " to 8 instad of 12. the clyte motors are 8 pole. ( this affects the speed reading using the hall wires i beleive )
