Can someone help me with the settings.
Is installed:
Kelly KLS7230S
QS engine 138 70 H
Battery 72Volt 69.6AH 150A
Shunt 0,25mOhm
There are 3 setups:
1. Basis Setup
2. Setup Battery
3. Setup Advanced Setup
Setup 1 and 2 is clear.
3. Setup Advanced Setup:
It will be difficult here, what do I have to enter here.??
Set Range ???
Set RSShunt= ???
Zero Amps ???
Volt Calibrate ???
Averaging ???
Seriel Output ???
PS Gain ???
IntSGain ???
IntAGain ???
IntVGain ???
ITerm Max ???
ITerm Min ???
Max Throttle ???
Set TotDist ???
Set TotAhrs ???
Set Tot Cyc ???
Aux Voltage ???
Aux Thresh ???
Vshuntdown ???
Is installed:
Kelly KLS7230S
QS engine 138 70 H
Shunt 0,25mOhm
There are 3 setups:
1. Basis Setup
2. Setup Battery
Set Range ???
Set RSShunt= ???
Zero Amps ???
Volt Calibrate ???
Averaging ???
Seriel Output ???
PS Gain ???
IntSGain ???
IntAGain ???
IntVGain ???
ITerm Max ???
ITerm Min ???
Max Throttle ???
Set TotDist ???
Set TotAhrs ???
Set Tot Cyc ???
Aux Voltage ???
Aux Thresh ???
Vshuntdown ???
