Hi there. I've installed a voltage meter like EVmadrid uses on some of his packs. I'm running mine on the handle bars cause I don't use a BMS and I'm also pulling power off the wire for a front light.
Anyhow I'm wanting to change the default setup to volts instead of percentage but it doesn't seem to change.
The instructions I found online which weren't delivered with the unit weren't very helpful. I managed to program the right cell count but if I try to bridge the contacts I'm pointing to in the pic with solder I get no change in the way it functions. What am I doing wrong here? I'm assuming you just solder a bridge between the two adjacent pads to get the desired change.
Also, I've read if I install a small piezo buzzer in the top right corner it will sound alarm when it reaches low voltage. I wonder what voltage piezo I should get? most only go from 3-14v. Is that ok or should I use the battery voltage and spec a buzzer that is capable up to 30v?
