UPDATE:
It's been awhile, so I thought I would do an update.
Still running two throttles, two controllers, two battery systems and dual Q100 (Cute) fast speed (328) motors.
The rear is the CST version that accepts a cassette.
The frame bag contains 10 Ah of 12 S Lipo configured 6S + 6S and 4S + 4S + 4S. A 6S side by side with a 4S makes the perfect width for the frame bag.
On top of the Batteries are the two rather large Elifebike 9-FET 350 Watt controllers. And on top of that, a rat's nest of wires.;
The 5Ah/12S for the frt. motor is still carried in the case below the down tube.
Since I only use 2WD about half the time, so the two battery systems discharge at about the same rate.
I avg. almost 1 1/2 miles per Ah at speed in the middle to high 20's mph.
With the two ELB controllers, two 810 meters are used to turn them on:
From left to right, half-twist left-hand throttle (rear motor}, thumb throttle (frt. motor), 810 meter, airhorn, Luminator from Grin, 810 meter {up-side down) and rear shifter. The frt. shifter has been removed
One of the reasons I like the LED meters is they match up to 12S Lipo (46V nom.)reasonably well.
At full charge-3 of the 4 lights lit.
At half charge-second lite goes out.
At 3.60V (cell)-last lite starts blinking
At 3.5V (cell)-The controller LVC kicks in and shuts down system.
There is a cell low Voltage alarm/meter on the frame behind the steering tube.
A while back, I replaced the org. crankset with a Shimano Claris 50 T gear wheel crankset that came with short 165mm crank arms. This helped to get some more clearance from pedal strikes. This is a good replacement for those with the Octalink system;
http://www.amazon.com/Shimano-FC-2450-Double-8-Speed-Crankset/dp/B00PUDERYW
And since going to 24"wheels, i had enough clearence to use a Sunlite drop rack with a taller bag(for my gal. of milk
Latest upgrade was swapping out the chinese pizza-cutter rims with wider Alex DM 24's.
This required longer spokes and after comparing the Chinese genaric 13 ga. spokes with bicycle size DT Swiss 14 Ga., I went with the latter
The DT Swiss stainless steel spokes seemed as strong or stronger and they won't rust.
Mounting the larger CST 2.4 X 24"Cyclops tires acerbated something I already knew. That is, a single high speed small motor, on a bike with a large rider, is pushing it.
On the flat, no wind, it will slowly lose mph from it's top speed of 23 mph and hills, well, forget it. The controller will heat up like heat lamp and it's efficiency goes all to Hell.
But of course, with two motors splitting the load, it's a different ball game and the bike acts much like a single larger motor on 30 Amps.
But the second motor adds a whooping 4 mph, rather than the usual 2 mph a second identical motor would add. This is because the single tiny motor runs out of power(current), not RPM.
Currently building an extra set of motor/wheels for lite trail riding.
2) Q100H's (260 winds), Alex DM 24 rims and 2.4 X 24" CST Holly Rollers that will be run tubeless.
Edit, later cleaned up the battery compartment;
