e-bike battery, pouches and 18650 cells for sale - Perth WA
jonescg
Perth, Western Australia
HI everyone,
I've got stacks of leftover 18650 cells for sale. I'd buy 1000+ of them, build a battery and have like, 70 left over. Not enough to start a new project, but too many for a simple project.
Red cells are Panasonic NCR18650BD cells (60 of them) - 3200 mAh and 3C continuous. $200
Blue cells are INR18650MH1 cells (77 of them) 3200 mAh and 3C continuous. $250
I also have a dozen of these 8 Ah Li-ion pouch cells from a previous project which never got used. You can feasibly build a cheap 10s pack from them if you found a reasonable termination system to work with. $100
Almost forgot - I have some BMS PCBs with connectors (3 at 10 A continuous, three at 25 A continuous) - these are from Mr Henry in China. All work reasonably well, and certainly better than nothing. $50 for the lot.
Finally, I also have a 48 V, 25 Ah (14s,7p) e-bike battery pack made from Panasonic NCR18650GA cells (3500 mAh) complete with a 40 amp continuous BMS. This battery is completely potted in epoxy resin, but the BMS can be removed if you need to. It hauls a 1000 W ebike up Crystal Brook Road no sweat. $300.
Prefer a local buys them to save on postage hassles, but will make the effort if you do too.
PM me, or email me christophergrahamjones(at)gmail(dot)com
I should add, the dimensions of the 48 V 25 Ah e-bike battery are 320 mm long, 140 mm wide and 80 mm tall. Weight is about 5 or 6 kg.
Update: 18650 cells are sold.
Ebike battery and pouch cells still available.
