that0n3guy
🔌 New-ish
- Joined
- May 2, 2015
- Messages
- 16
Hey All,
I'm building an electric mountain board and I thought I would post my research before buying anything.
Background
I bought a used mountainboard about 10 years ago ($25 at a garage sale http://www.sierratradingpost.com/mountainboard-sports-ambush-warrior-mountainboard-~p~99877/) which I motorized with a drill battery geared down twice... motor doing about 18k RPM and 12-24V SLA's. It sucks
. I just started doing some research and man has battery and motor tech come a long way.
Project Description
I'll rip off my old motor mount and remove hand brakes. I want to use this thing for commuting to work, mostly streets. I work 2-3 miles to work with a couple hills around 15% grade (according to google earth) that are only a block or so long. I don't want to spend a lot (actually, my wife doesn't want met to
) so I'll probably stick with single wheel drive. I probably don't need more than 20mph (~32kmh)... if I did, I would just ride faster and hurt myself (you should have seen my sweet black eye after snowboarding this year).
Research:
Gearing, battery, motor:
Based on vedder's article (http://vedder.se/2014/10/chosing-the-right-bldc-motor-and-battery-setup-for-an-electric-skateboard/)... this is how I selected my motor gearing and battery:
Battery options for 12s:
Motor:
Based on vedder's article:
Two motors that look close:
http://www.hobbyking.com/hobbyking/store/__18129__Turnigy_Aerodrive_SK3_6374_192kv_Brushless_Outrunner_Motor.html
http://www.hobbyking.com/hobbyking/store/__18181__Turnigy_Aerodrive_SK3_6364_190kv_Brushless_Outrunner_Motor.html
I think the 63mm motor is a good idea for a single motor board (higher torque).
Gear Ratio:
http://www.advanced-ev.com/Calculators/TireSize/
RPM: 8600
Tire Diameter: 8.75 (8.5" to 9" depending on air pressure)
MPH: 25
Differential Ratio: ~1:9 (this seems high... I don't see this type of ratio anywhere on this forum)
Chain vs belts
I looked all over SDP-SI and it doesn't look like there is any way to get anything above a 1:6 ratio with belts (since the motors have 8mm shafts). To get higher gear ratio, I have to go chain.
http://www.sdp-si.com/eStore/Catalog/Group/218#
Wheel sprocket:
sdp-si has lots of hubless carbon steel #25 sprockets from 70-100+. Depending on the steel type, they might suck to drill. Looking for alternatives.
80T #25:
http://tncscooters.com/index.php?route=product/product&product_id=131
http://www.electricscooterparts.com/sprockets25chain-wheel.html
http://www.partsforscooters.com/127-1?sc=31&category=132535
http://www.monsterscooterparts.com/25sp80to2moh.html
http://www.staton-inc.com/store/products/80_tooth_25_A_Sprocket_2_13_ID_with_four_Mounting_holes-1752-45.html
http://www.extremescooters.biz/127-1.aspx
(#25 I think): http://www.amazon.com/Sprocket-80-Tooth-Scooter-Chopper/dp/B0085MCPSK
This would probably work well and are all over the web (electric scooter and pocket rockets use them)... 1:8 is close enough to 1:9. A thread: http://endless-sphere.com/forums/viewtopic.php?f=28&t=9551
Attaching wheel sprocket to the wheel ideas:
- create an adapter like: http://endless-sphere.com/forums/viewtopic.php?f=35&t=68710#p1036962
Motor sprocket:
11T #25 A 6C 7MHC25011 (8mm bore)
10T #25 A 6Z 7M251008 plastic (8mm bore)
10T #25 A 6C 7MHK2510 Steel (8mm bore)
10T #25 Aluminum (http://www.andymark.com/product-p/am-0505.htm)
ESC:
I'm not even going to waste my time on a car ESC. VESC is the way to go. If I can't get one from someone, I'll have one made (I'm to busy to build it myself... my 3rd kid should be here any day now).
Controller/reciever:
I like the wii remote idea. I've not done too much research on this one yet.
I think I need a reciever of some kind that hooks into the VESC... is that true? Looks like there is a $50 one on torqueboards site.
Charging + other electronics
Questions
Notes from research:
Lower KV motors have higher torque... higher KV, higher speed.
Background
Project Description
Research:
- - Higher voltage = lower amps = good
- I'll probably use 12s (about as high as I can go based on current ESC's)
- - 4x 3s-5Ah 20c = 22.10x4 = $88.40: http://www.hobbyking.com/hobbyking/store/__16786__ZIPPY_Flightmax_5000mAh_3S1P_20C_USA_Warehouse_.html
- 2x 6s-5Ah 20c = 40.43x2 = $80.86: http://www.hobbyking.com/hobbyking/store/__9176__Turnigy_5000mAh_6S_20C_Lipo_Pack.html
Motor:
- 12s (this is what I will use):
3.8*12 = 45.6v
8600 / 45.6 = 189 KV
Gear Ratio:
RPM: 8600
MPH: 25
Chain vs belts
Wheel sprocket:
80T #25:
Materials:
- G10: http://www.mcmaster.com/#grade-g-10-phenolic/=x2f7pp
- ALUMINUM (.08-.125" in 6061) http://www.mcmaster.com/#standard-aluminum-sheets/=x2ff65 http://www.onlinemetals.com/merchant.cfm?id=76&step=2&top_cat=60
- polycarbinate http://www.onlinemetals.com/merchant.cfm?id=270&step=2&top_cat=181&showunits=mm (no idea if this is strong enough.. but its cheap)
- GPO - Stronger than poly, cheap https://www.onlinemetals.com/merchant.cfm?pid=17915&step=4&showunits=inches&id=1264&top_cat=181
Motor sprocket:
ESC:
- - IMAX B6 - http://www.hobbyking.com/hobbyking/store/__5548__IMAX_B6_Charger_Discharger_1_6_Cells_GENUINE_.html
- Power supply - The original xbox 360 power supply would do 12v @ 16.5amps... easy to find on ebay for $10: http://www.ebay.com/itm/Xbox-360-power-supply-203-w-watt-FAST-SHIPPING-/111659543956 (look at the plug for version: http://support.xbox.com/en-US/xbox-360/system/power-supply)
- A paraboard (parallel board) to charge my 3s's or 6s's in parallel
- A cheap amp meter
- A cheap volt meter
- a lipo sack like: http://www.hobbyking.com/hobbyking/store/__4364__Lithium_Polymer_Charge_Pack_25x33cm_JUMBO_Sack.html
- Something to let me know batteries are getting to low....
Questions
- - Which battery setup should I do? 4-3s seems like its most flexible from a layout of battery standpoint.... and cheaper/easier to replay battery packs (that idea was from torqueboards guide).
- What is the difference between the 6374 and 6364 (beside 2kv)?
- Is that gear ratio crazy high?
- What do I need get the wii controller and VESC to communicate?
- Does my xbox360 power supply idea look good?
- Any suggestions on extra electronics (see my section above)?
- How do you do onboard charging? I would like to not take my batteries out of the box. How do I wire it to do this?
- Anyone have a good source for custom 80-90T sprockets?
