Gregory
For the old style Shenzhen ecrazyman controller I'm getting 4 flashes on the error LED.
I may have shorted out one of the hall wires as I have a temporary joiner down on the seat stay from motor output to the main wiring loom, but I have tested the halls and they are all OK (.05-4.86V). Connections all seem OK.
Wheel doesn't even try to move. Twist the throttle and there is an almost inaudible click inside the controller.
Does anyone know what the 4 LED error flash code means?
Thanks, Greg
In the Shenzhen Controller info thread , http://endless-sphere.com/forums/viewtopic.php?f=16&t=9046
Thanks, Greg
Fechter said:From what I can tell, the codes are:
No light: Motor running
1 flash: Standby, motor stopped
2 flashes: Throttle input fault or HV brake active
3 flashes: Locked rotor (start speed protection)
4 flashes:
5 flashes: High side FET shorted
6 flashes: Hall sensor fault
7 flashes:
8 flashes: Under voltage (LVC) active
Not sure about 4 and 8. One is most likely an overcurrent fault
