RVD
How do electric brake levers work?
I have a lyen controller (12 fet) that has 2 wires for the brake lever. I used to have this installed so that when I pull on my rear brake lever with my right hand, this causes my motor to brake in addition to engaging my rear brakes. However, I recently changed out my rear brakes to hydraulic disc brakes so I put in a new rear brake lever.
I like the peace of mind of having a rear brake lever that will also help kill the engine. I also have an emergency kill switch. This stuff is important to me because I once had an incident when my throttle malfunctioned and went to WOT and wouldn't stop. Luckily I was not out on the street riding the bike at the time but instead I was at home and just getting on the bike when it happened. It was a scary few seconds as the bike went crazy and as the wheel started to move really fast, i somehow found my kill switch and pulled my emergency kill switch that killed the engine and stopped it. People here told me that if I was out on the street I would have probably instinctively engaged on my brakes that the electric brake would have stopped the motor as well. I have since replaced the throttle with a magura throttle.
I am thinking of just installing the same electric brake lever next to my new one. It will look a little funny with 2 brake levers on the right but I think I'll get used to having the option of using one or both.
Can the electrical signal get sent to the controller to kill the engine by pulling on the brake lever even if I don't have brake cable there?
RVD.
RVD.
