I am an old man who sometimes momentarily lives in the past when I was young and strong and beautiful and wild and crazy. Once upon a time,
many years ago today, I rode a 58 Triumph TR6 with aftermarket cams and capped megaphone exhausts and a trick sprocket which was actually OVERDRIVE one tooth. It got on the cam
rather abruptly at 2800 RPM and would do 70 MPH at 9,000 RPM
in low gear. Usually when I was trying out zero to 60 I would shift from low to second at 50 or 55 because it began to get flat at about 45. It was factory rated at 42 HP (I vaguely remember) and I ran dead even with a box stock 61 Bonneville rated at 46 HP (I vaguely remember)in numerous comparative acceleration science experiments in the quarter.
I ran the quarter too many times to count. My best and worst et's were 14 flat and 15 flat. My best and worst trap speeds were 105 and 95 MPH. Traction was a real problem. The bike bogged unless the RPMs were above the critical 2800. So I had to either spin the tire for 50 feet or slip the clutch. Most of the time I spinned the tire.
The published weight of the wet bike was about 375 pounds. At that time I was a skinny punk teenager that weighed a dam lot less than Arnold Schwartzeneger. Total vehicle weight maybe 500 pounds or a little bit more. More if I was wearing my Harley Motor Davidson black leather jacket.
Total weight ~500 pounds. Total HP ~45 HP. WEIGHT/HP 500/45 = 11.11.
If we assume (only approximately true) that the ratio would hold true for a 400 pound kart (sounds like a HEAVY kart
) then you would need 400/500 x 45 HP = 36 HP to get the same performance of roughly 100 MPH in the quarter.
I figure that the air drag of a kart will be pretty close to same as the air drag of me on my Trump through a quarter. And the traction situation is not really comparable. The prevailing conventional wisdom of drag racers is that weight/HP is what gives the speed through the trap. Losing traction off the line is what determines et elapsed time.
So now, how much is 36 HP in WATTS? I will figure it out after just one more beer OK. :wink: But after another beer I may forget to get back. So best
you figure out how much 36 HP is in watts without depending on an unreliable old man.
