Was racing this sunday with retro karts again
Big thanks to Craig for selling me Zero 75-7 motor and Biff for helping me out with the config when I was stuck and all hope were lost
Had to configure sevcon "profile 1" to 4400rpm limit, because thats when field weakening starts. And with it the motor will heat up more quickly.
I also had 48% torque demand on that profile. But as I have a little button on wheel from what I could trigger "profile 2" where torque demand was 100% and rpm limit 6000 then it was fun using it 4 times in the race. But as you can see each using of it raised motor temp for 7 degrees instantly.
Here is video with data. I struggled with the motor conf in first 2 races, thats the reason I was easy on first two laps with the throttle in final race.
https://youtu.be/pbdnJMd8Reg
I have two extra temp sensors that are measuring motor external temp and controller extra heatsink temp. I have covered the motor sensor with foam tape so it does not gets cooled.
Does anybody know why Sevcon's motor temp is 10 degrees higher than controller one when both are not used and should be at ambient temperature?
I have it configured as KTY84 in combobox as it should.
Total weight of the kart including me on board was 234.8kg, so its should be little lighter that zero motorcycle?
