sean
So I have about an Acre lot to maintain, and i have an OLD 1972 Bolens 1556 Hydrostatic Tractor. This is about the same size as a large riding lawn mower but weighs about twice what one would at around 800lbs. It has Hydraulic lift, shaft drive front and rear PTO.
Not mine but similar:
Maybe my end result?
of course with a motor and batteries as ballast
Currently it has a 15 hp Tecumsuh ICE POS with a 4 belt pulley on it 2 belts driving the hydraulic pump and 2 belts driving the PTO when engaged. The engine is on it's way out and has been getting progressively worse, I have been thinking that rather than putting a honda or other ICE engine in there I could convert to Electric. There is room enough I think I could put enough batteries in there, and the weight wouldn't be a negative feature for a tractor as it is just added traction.
I plan to get a Hydraulic "12V power unit" such as This one:http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200329764_200329764 available from Northern Tools with a trasducer set to trigger the solenoid and run the pump when pressure drops. Or make it work on pedal actuation and lift use. Anyway just not running the hydraulic pump all the time unless you are driving and when it is necessary.
I still need to find the hydraulic demands for the transmission on the tractor and ensure that the power unit I get matches the pressure and rate demanded.
What I want to know is what size and type of motor should I plan on using to drive the PTO? The impliments I currently own are a 42" belly mower a 36" rear tiller and a 54" sickle mower. I imagine that the tiller would of course take the most power to drive, it would be REALLY handy to be able to control the PTO speed independently of the drive speed...
So I currently have a full size car battery in the tractor and have room for probably another 3-4 deep cycle 12V batteries, where the engine is if I can manage to fit the hydraulic power unit and use a compact motor such as an E-tek in there. Maybe even 5 if I shifted the motor very low.
I think it would be wise to refab the PTO to accept #50+ chain and/or use a dual roller drive, I need to find the load specs for the chain and determine what would be the load.
Would going from Belt to chain be a wise choice here? I think I might start with Belt for Ease of Installation but I know the frictional Loss will be Horrible.
In general I think that I could run the Hydraulic Unit without a controller but rather some sort of switching wiring that would allow it to only come on when the ignition was on and when there was a demand for hydraulic pressure. The impliment hydraulic Lift will remain in place without pressure being generated.
So What type of Controller would be desirable to control the PTO motor? I would like to be able to control the speed of the PTO and I need to again confirm the RPM that the PTO operates at and choose my motor and voltage accordingly.
I have been looking here at parts..:http://www.evparts.com/shopping/mainpage.php?id=3
So what are some problems to my plan?? I know there must be some...
I am thinking if I got a Etek for 300-500 and a hydraulic unit for 2-300 then I could get enough batteries and controller for another 500 and have an electric conversion for about what it would cost to do a Honda conversion... Electric would of course be a HELLUVA lot slicker than a honda!!
Thanks for you constructive input!
