Hi, first post. I could use some feedback for a possible e-bike conversion project. This would be my first, but I've been studying up on it (mostly by reading here). I have a Surly Karate Monkey that I've been using for a townie/trail bike. The build ended up being heavier than I was expecting. Those big tires are heavy, plus the other stuff like butterfly bars, rack, annd sprung seat add up. I might get another, lighter bike this summer for leg-powered exercise and trail riding. That idea started me thinking about motorizing the Monkey as a short haul bike for shopping in my small town.
My house is up on a hill and there's a grocery and hardware store down on the flats, just a mile away. I think it's about a half mile of 5% or 6% grade for the hill section. I can't use the bike for this now, because I'm an older guy with bad knees, and pedaling a bike with panniers loaded with groceries up that hill is just too daunting. There is also a nice state park 2 miles away, with a very short stretch of 15% grade climb on the way home. I have to walk the bike on that section now, and I could probably pedal it with enough assist. I don't want an e-bike that works like a throttle-and-go motorcycle, just some help on the hills, and (hopefully) low rolling resistance so I can pedal most of the rest of the way.
I'm thinking maybe a geared front hub motor for this project, although I'm open to other suggestions.
I would like to keep the big tires (2" Big Apples) for the shock absorbing and easy rollover on bumps and pot holes. Will a pre-built front hub motor kit have rims wide enough for these tires? Am I looking at a custom wheel laced around a motor? I would need a kit where I could keep the front disc brake.
There are some other ideas I'm mulling over, like getting a cargo bike for the donor so I could carry larger, odd-sized stuff home from the hardware store. The Monkey would be limited to what could fit on the rear rack; probably grocery panniers with the battery in a waterproof case on top of the rack. I thought I'd float the idea of using the Karate Monkey first, since I already have it. Also the name "Electric Monkey" would be cool.
Thanks in advance for any feedback!
