warkdouglas
10 µW
Hey guys,
I am going to be attempting a project and I want to run a few things past some of you guys who have experience building these boards. I am planning on building my own version of a GolfBoard, which is very similar to a mountain board. I just don't feel like spending 3,600 bucks. I would say that the only difference will be that it needs to optimized for much slower speeds and a bit more weight capacity.
So far this is my plan. I am worried that normal mountain board deck will have far too much flex for this application, so I am planning on making a custom aluminum deck, using 1/2" aluminum with about 60-80% milled out. I am hoping this will be more rigid and also allow the entire deck to about 6-8 inches off the ground. I have tools to make my own deck, motor mounts, etc., but I have very little RC electronics knowledge, and I don't want to copy someone's setup only to find my board is completely gutless and/or have something explode.
So my biggest issue is figuring out the proper motor, esc, battery, transmitter combination to make this thing work with as little hassle as possible .
I would like two motors for traction but I need a setup that only has a max speed of about 10-15 MPH, slow but powerful takeoff, hopefully a reverse, can take off from a dead stop, and that has approximately 8-10 mile range (36 holes of golf). I also need a brake that can lock the board in place. I don't know if any rc motors are capable of that or if I need to install a separate cable brake.
Anyways, I was hoping some of you guru's out there could give me some advice on the best and easiest setups.
Thanks
Thanks
