Pedrohlt
Hi,
I'm working on a electric mountainboard. Here is the specifications:
Board - MBS Atom 95X
Motor - Turnigy 63-74 200kV Outrunner
Batteries - 6 or 7 ThunderSky 40Ah LiFePO4 cells
Controller - LVC Disabled E-Crazyman 72V 45A 1500W (I blew up my Suppo 100A ESC)
Throtle - 10k slide pot
Here is some pics:
Hall Sensors Mount
SS411A
The problem is that the controller don't respond to any command, the only thing I noticed is that when I plug the conectors it sparks(maybe cause the capacitors are charging). I thing the problem is that I'm using only 6S LiFePO4 (I have one spare cell to make 7S) and the controller don't work with low voltage. When I bought the controller from ecrazyman I asked if he could disable the LVC because I'm gonna use 6S, and he said its ok, he can disable the LVC. So, I though that with the LVC disabled the controller should work with 6S, but it's not. And I don't know if the LVC is really disable.
So I'm asking you guys how can I modify the controller to work with low voltages(6 or 7S) ?
Pedro.
Here is some pics:
Hall Sensors Mount
SS411A
Pedro.
