Braddudya
⚡ Regular
- Joined
- Jan 30, 2022
- Messages
- 143
My wife and I bought our first house. I probably have a million way more important things to do but I can't help exploring building a small electric skid steer for working around the property.
Objectives for skid steer:
Haul up to 1000lbs of gravel, rocks, concrete, lumber, tools, etc
Plow driveway
Front bucket - move and spread gravel and light dirt work
Wishlist:
Fork attachment to move pallets
Lawn Sweeper attachment
Onboard inverter for mobile AC power
Initial Exploration:
I want it to be as simple a machine as possible. My first idea is to simply use 4x or 6x high torque low speed hub motors. The best I have found so far are these.
If I run the 4x config I could use 2x vesc dual output controllers. Using stick controls I could have the right stick control the right two motors and left the same. From my initial reading it should be possible to implement electronic braking (assuming no free wheel) and traction control. I may need some sort of mechanical brake for parking and/or additional braking for hauling heavy loads.
Battery:
One reason this project seems doable is that I am sitting on a bunch of lifepo4 a123 cells that could be used for a "free" (money currently wasted) battery for this thing. I don't think I have enough to give it a long range but I'm sure it's enough to haul some stuff around the yard for awhile.
Questions:
1. Is it realistic that I could get a skid steer like experience using these high torque motors and electric braking from a setup like this? Can I setup the controller to actively brake (opposing magnetic force) and mostly avoid mechanical brakes while driving?
2. Do you all think this is a silly idea? I would like it to actually be able to reliably do dirt work and climb hills while hauling heavy loads. I could always buy a gasoline standing mini loader or just rent a bobcat instead. I am certainly capable of welding up a heavy frame and building the battery to support it but I'm not sure if these available hub motors are up to real work and I cannot find many cases of people putting them to work.
3. Would you recommend an alternate configuration? Maybe 2x high roque motors with chain drive to the wheels?
I guess I am asking the impossible question of does this idea make sense or am I going to end up with a silly yard toy haha.
Plow driveway
Wishlist:
Battery:
Questions:
