Hi guys, david wood here from Brisbane Australia.
Im looking to build my own electric tricycle, and i've had a few ideas as to what i want - but i would like some suggestions and support before i start.
My first thought was getting one of those greenmachine trikes, tearing the frame down and building it back up from there - However, the tube steel is only very thin from memory, and im not sure it will support the weight i will have on the vehicle.
My second thought was to buy two identical mountain bike frames, tear them down, cut and weld as necessary and build up from there - Again, unsure of the stability of the frames.
My third thought however, was to build a basic trike frame from 25mm RHS Steel, use some bike parts (steering colum, front shocks, brake lever's and disc breaks, and maybe the gear system from the mountainbike as well).
My goal for this project is to make a reasonably powerful electric tricycle (500w - 1000w), with a top speed of around 30KM/H, and a range of about 5Km's before it needs charging.
I know a fair bit about electronics and electricity, so my questions aren't really about that as such - but more so about the actual design of the electrical system (which motor, voltage, gearing system, etc)
From this diagram i've come across, i know i wont need much in the way of electronic components.
Here's the current parts list i have in mind for the moment.
24v 1000w Permanent magnet DC motor
24v 20amp Electronic Speed Controller
Electric handle throttle for speed control
2 x 12v 20Ah LiPo batteries (the ones used in RC hobby stuff) - Wired in series for the motor
The on/off switch will be a 12v key ignition i have lying around, and the batteries i will charge from my 24v solar charge controller.
Has anybody got any thought on any of this?
Or if you've done something similar, i would love to see your work and understand how you did it.
Thanks!!
Thanks!!
