Mihai_F
- Joined
- Oct 11, 2021
- Messages
- 177
Hy there,
I will present here my electric drift trike build, with details for mechanical and electrical parts.
It all started after i decided to migrate my projects to STM32, then started to make my FOC code and controller, here is the FOC thread FOC questions So i needed a "vehicle" to test my controller and code.
Here are some mechanical specs: it has 250mm back wheels, 20" front wheel, a 1800W 48V Vevor 1020D inrunner brushless motor 9teeth pinion and 54 teeth sprocket 1 to 6 gear reduction ratio, T8F chain, i'l put PVC pipe over the back tires in order for them to be able to slide and drift, frame is made out of mainly 40x20mm some15x15mm rectangular steel tubing, and some 25x25mm L steel profile, back brake is 160mm disc mechanical brake, front is typical bike "v" brake, the back shaft is 20h9 mm C45 steel calibrated bar, all controls on the handle bar are from e scooter standard parts.
Here are the electrical specks: the battery 60V 16s7p 12Ah will be borrowed from my e scooter, the controller will be a 6 fet (FDBL86062-F085) or 12 fet (FDBL86210-F058) FOC, il present it in mode detail as i go on, so far is a development variant made with 6 IRFP4468 with some gate driver board remained from my 300A ESC old versions. So with that 60v batt i plan to abuse the heck out of that 48V motor, for future i plan to make a custom motor for it, will se.
Here are some photos as the build goes on:
