NeilP
1 GW
Just went round to a mates house today, as he has just got his first bike built. He bought a kit of parts from Elecrtic rider, and a pack of LiFePO4 from Jim at Headway Headquarters
Not sure exactly which motor apart from it is a rear sensorless HS/HT series Xlyte, with a 72 volt 40 amp sensorless Xlyte controller
Pack is 48 Headway cells, half int he frame and half in rear mounted box, with the BMS and the controller.
He does not yet have the Xlyte "CA' but wanted to know how fast it was going.
We went out for a ride around the block, and got just on the 40 mph out of it. Came home and all was fine. He was a little worried about how warm the controller was getting, so he opened the lid on the rear box to show me and also flick the off switch on the back of the controller.
As he lifted the controller out, the was a feint sound of a spark...nothing big like the spark when you connect the batteries to a controller without a pre charge resistor, just a very quiet 'tick' that had the wind been blowing strongly you probably would not have heard it.
The only connection on the controller that were made were the throttle, battery, and phase wires to motor.
That leaves 4 plugs not connected: Brake cut off, cruise, Xlyte CA and and a two pin plug with a jumper. Was assuming the two pin with jumper was possibly a regen brake enable.but since this is a sensorless controller , this could well be a motor adjustment plug..not sure what to do with that or how it works.
All these leads are all fitted with the small black multi pin connectors.
Anyway..after this minor spark, there is now no response from the throttle.
The LED on the controller is on, but nothing happens when throttle is turned.
I took one end of the controller off, and checked for loose solder, swarf etc creating a short inside the board, but found nothing, removed the board and all at least looks OK ..nothing obviously burnt.
He did not have a multi meter that worked, so we could nto check any more then, so I took controller home and have verified that there is 5 volts out of the throttle plug, along with the battery voltage on another pin ( 4 pin throttle)
All we can see or think of that may have caused the spark, is one of the terminal on one of the unused plugs coming briefly in to contact with a metal part of bike/battery box/controller
Did wonder about the BMS tripping...but if that had happened, then I would not imagine the controller power LED would light up at all...but maybe I am wrong...does a Headway BMS cut all power when there is a short condition...or just cut main power and leave a low current battery voltage still up and running?
Anyone any ideas...what to try next?
Since we are in UK and it would mean sending the controller back to Canada, want to try all we can this end first.
