I'm building custom dual motor e-scooter. Two diffent controllers and 2 different display. I know how to connect everything but brakes are a bit mystery to me. I need that kind of electronic brake to my front motor that just not cut off the power but really slow down the motor. I have that type of brake and controller now in my rear motor. It has regenerative 3 wire brake input and it slows down the scooter but not enought. I don't want to apply 2nd similar controller and display to this system because the current display is original and is mounted to the scooter so I want 2nd display (e-bike's s866 or similar) to be located in a handbar where I can adjust the front motor separately. This is also an esthetic solution. I can't apply any mechanical brakes to this scooter due to a front fork fitting problems. And to the rear motor it also would be difficult to put any mechanical brake system. So I need 2 electronic brakes that not just only cut the power: to rear and front. Thank you if somebody would like to answer my guestions. I'm a little confused and not finding spesific answers to these guestions.
MAIN GUESTIONS
What kind of controller and brake lever I need to have stopping/slow down power in electronic brake?
Does the controller must have regenerative braking capability and 3 wire input to truly slow down the motor when brake lever is pulled?
Can it be 2 wire input and it's then slowing down the motor when lever is pulled. Does it still need to be regenerative controller? I've tested 2 wire brake lever which goes to 2 wire input in controller (not regenerative controller). Only thing it does it just cut off the power. Useless to me when I need some slow down/stopping power. I can get the very same result just releasing the throttle.
Are there even 2 wire regenerative input controllers?
Are there 2 wire brake input controllers that have slow down capability and not just power cut off and this without regenerative capability?
Is it possible to connect rear and front controllers electronic brakes both to one 2 or 3 wire lever? How the connections would be? Does the 2nd controller only need a signal wire from the other controller's brake input just like a throttle in dual motor/controller system or do I need to connect all 2 or 3 wires to the same lever?
If I buy controller that says it has EABS and 3 wire brake input, does it then automatically have capability to slow down the scooter or is it similar to my experience of 2 wire input controller and it just cut of the power but not actually brake? Is EABS 3 wire controller automatically regenerative?
And what about if controller says it has linear EABS. Is it then regenerative or is it just normal braking system without regenerative capability but still truly brakes and not just cut off the power?
Can low level and high level brakes both be regenerative or is the regenerative totally different thing?
MAIN GUESTIONS
