Chalo
100 TW
doctorGONZO said:Now to your "question-answer". My question was: "I will enjoy reading your detailed explanation of how you plan to avoid Gravity Drag." Or something like that, because in your post it sounded like you thought an Orbit Elevator could avoid it. You have so far failed to explain how an Orbit Elevator traction system turns off gravity. You did by fiat say that gravity does not drag the elevator down, but I already had it figured out that you believe that.
Then you don't understand what aerospace engineers mean by "gravity drag". It's not the force of gravity, or the work required to raise a mass against the force of gravity. It's the work a flying machine has to do before being able to rise away from the ground. A rocket first must burn enough propellant to hover, and then must add more thrust to move upward. The amount of thrust required to hover is gravity drag, and an elevator-- the space kind, the regular kind, or a funicular-- does not have any. It has mechanical traction instead.
It's all irrelevant because we don't have the materials for a space elevator cable, nor the will to throw that much treasure at a project even if the materials were available.
