Hey guys!
I've got 2 cents for some here......... It's my Pet Peeve.
In my opinion...... one should think in VOLTS with Amps rather than Amp's alone when wire sizing.
The Higher the VOLTAGE the less resistance as electrons flow faster
I'm very efficient running 144v HOC and always above my nominal voltage of 128v on 40s LiFePO4 and using a 28mm 10wind motor
Even with my lower voltage controller at 88volts @ 76.8volts nominal, I'm finding that a 10wind motor gives great inefficiencies.
That being said, I'm also current limiting to 30amps in both scenarios about 4000watts at 128v and 2400watts at 80v. Also, sizing
Cells/batteries is paramount in order to reduce the possibility of damage to Cells/Batteries. You won't have SAG if you SIZE!
Just keep in mind.... the lower the system (controller/battery voltage) the larger the wire.
If you look at a Car, the 12v starter gets the Big Wire. Sometimes as big as 2 gauge for larger engines. At 12v and 100amps, that 1200Watts of WORK!
Then look at house wiring.... 15amp circuit at 120v on a 14 gauge wire (1800 watts).
This is why I love Higher Voltage Electric Propulsion
This chart below is for reference and of short runs. Step it up a size if longer wire runs are need.
This is not a perfect chart. Do your RESEARCH before attempting any electrical ventures!
Tommy L sends.......
Gauge ..110V ....12V............Watt's
22 ........5A ......5A...............550 vs 60
20 ........7.5A ....8A..............825 vs 96
18 ........10A ....10A.............1100 vs 120
16 ........13A ....20A.............1430 vs 240
14 ........17A ....40A.............1870 vs 480
12 ........23A ....60A.............2530 vs 720
10 ........33A ....100A...........3630 vs 1200
8 .........46A ....150A..............5060 vs 1800
