EM5.7 is an Electric Motion Trials Motorbike.
My battery has been over discharged (1-2V per cell) and the BMS will no longer allow it to charge for safety reasons.
I was happy with the range and performance of the motorbikebike and would like to keep this economical and simple to get the bike back running. I can re use the charger and maybe even the BMS if its decent. Here are the specs:
Charger: ROHS LiPol 54.6V 15A
Battery: 25Ah and is a 13s
pouch type cells and there are 13 in series no parallel runs. Non of them are swollen or puffed
Motor: 5KW Golden motor
Controller: Kelly controller KEB 48601 (nominal voltage of 48v)
BMS: BNT-MP-M1005-001
All cells together are:
Width 10 1/4”
Height 7”
Depth 4 1/8”
The whole Pack was labeled: 82255140H[1178.45Wh] KHL13S1PXG6A013
Each individual pouch cell was labeled: KOKAM CO.,LTD SLPB82255140H, 90.65Wh KHL11XDRY0007 A7
I searched all these numbers but found nothing other then KOKAM makes batteries for a large variety of things
Looks like these pouches are li po and are supposed to be 3.7v each totalling 48.1v total with 13 in series
No parallel batteries so the 90.65Wh / 3.7v = 24.5 Ah per cell and for the whole pack
How do I determine the C rating of these batteries ?
Where do I find pouch batteries of the same size and Ah rating ? Most of the ones I can find are smaller
Should I get a new BMS like a speedict Neptune 15 or is the one i have decent?
Is it better to build a new pack out of a different type of cell ? What is popular now ?
I looked at the 21700 cells at 4000mAh , 13S 6P for 24Ah out of 78 cells but they are expensive!
Width 10 1/4”
Height 7”
Depth 4 1/8”
