smeagol222
I'm wanting to upgrade my "Emmo x" 48v lithium 500w scooter as I'm frequently carrying an extra person. Starting from stand-still up a hill sucks, there is no torque.
The most important thing for me is torque, I actaully dont mind being capped at 32km/hr, although 50 or 60 would be nice. To get more torque amps need to be increased? This means I need a higher wattage wheel and do the math (battery voltage x controller output amps)? either way I figure higher numbers the better, and I can limit the speed via controller later.
So I want to re-purpose a spare 48v 20ah lithium I have by combining them both to make 96v, upgrade hub wheel to 5kw (maybe less maybe more) and controller to 96v.
96v controllers seem to be priced (ebay) around $200, but say 1500w which may be too low. After some googling I found some on "kellycontroller" (not sure if they come with cables) and "goldenmotor" (chinese site). The golden motor ones seems to be for BLDC- not sure of it is different to hub wheel? both of these seem super expensive
The replacement wheel 5kw or so I'm thinking from "uumotor" (if you google '16 inch 5kw uumotor' its the second result)
The battery comes in a plastic box with handles which fits into the floor of the e-scooter. I've done measurements of the space inside and each battery, and both should fit once some padding has been altered. (see image)
I since I already have both chargers for each 48v I didn't really want to fork out for a 96v charger. I also thought that combining 2 batteries and using 1 charger might be a bad idea, since the cells wont be matching/balanced?
I was thinking just to add the charging port for the re-puposed 48v integrating it into the plastic box. There is a problem though. The current setup has a plug charges the original 48v battery and the same plug supplies power to the scooter. If I connect the batteries in series this would cause a problems when charging? Would I perhaps have to seperate this plug into 2 (one charging and one power output).
If the 2 batteries are connected in series only on 1 side (lets say positive) and they are hooked up to seperate chargers, is this going to create a bad thing?
I've tried to explain what I mean with some crap sketches.
I guess the other option (v2) would be to wire the second battery into the breaker, although this seems like the most simple approach I'd really like to have both batteries in 1 plastic unit and just plug in both 48v chargers.
EDIT
I Seem to have found some extra info about charging each one with 2 chargers - its okay to have one pole connected =) see image
EDIT
