Hi there guys, I've just bought a evt 4000e electric moped, it's 36volt 200 watt, it has 1100km on clock, it is a clean bike, I bought it as spares or repair.
I've took the motor off and one of the 8 brushes had come out inside the motor and jammed the real wheel up almost to a stop, and where the owner had been giving it throttle with the wheel more or less jammed up it's burned the controller out, the motor wires got hot and touched together and burned the controller out, the motor wires touched together right at the point where the come out of the shaft to wire to the motor, I hope people get what I mean as it's hard to explain.
I've put new brush in motor and clean motor out and put the rear wheel back together, I've put the motor wires to a 12 volt battery to test it and the rear wheel spins as it should and it's not stiff no more and free rolls as it should.
My question is where can I buy a controller from and how much are they? They have some on eBay but they have wires for throttle where as mine has a throttle cable that pulls on something on and in the controller?
Can I buy a throttle that don't have throttle cable and is a wired throttle and fit that to the bike with a different controller?
My grammar is poor and I hope you can make sense of what I'm saying and asking. Thanks for reading
