I agree, the 36v heinsmann is a good motor, even if loud and brushed. Great tourqe for sure.
But I don't agree that they are durable in the 24v version. That one is less robust than the 36v version. I overvolted one, and stupidly left the temp sensor disconnected for a quick test ride. It was quick, all right, I totally melted the motor in less than 30 min. This was on a different controller, so I was overvolting and over amping the thing.
Later, I put another motor on 24v, but more amps, and had good results, with the temp sensor. As long as I used the sla's they would go dead before the motor got too hot, but when I went to nicads, I'd have the motor overheat every ride. But these were the 24v motors, the 36v one is supposed to be much more sturdy.
If I had the $400 avaliable, I'd buy a 36v EVG myself. Some of the parts can be sold for a lot, or just sell the motor and use the frame for a different build. It's a great frame. Putting the motor on a really good FS MTB frame is another good option, with some lifepo4, you'd have a good motor for climbing, but I'd monitor the temp of the axle stub on steep climbs. If you buy it, and part it out or something, keep ahold of the headlight, it's really a good one, and can run on any voltage from 24-48. The tailight is 36v only though.
