bobc
I just started another project - as described above.
It seems to offer the best aero, safety & performance & range compromise for electrification.
Being a trike (3 wheel tracks, you can't steer round the potholes) & reasonably pacy it will need suspension.
So the rear swingarm pivot will also be the layshaft/jackshaft bearing (jackshaft will run on angular contact bearing pairs, swingarm will pivot on needle rollers).
The electrics will be LiPo, ESC & RC outrunner with belt drive to jackshaft.
I've designed some custom front hubs, outer bearing is dual row angular contact bearing, inner one normal deep groove bearing.
I've made the first purchase of mountainbike spring/damper units off ebay (850lbs/in 35mm stroke)
This was partly inspired by our greenpower racer, which we made using vacuum bagged composites, FRP over foam core shaped by our 3d router - does a lovely job & it's quite easy.... Those cars will take a person well over 100 miles at 30mph average using 80Ah at 24V. The faired recumbent trike is the nearest thing to one of these cars that you get to see on the road. My ebike uses more juice than this going below 20mph.
For the front sus I'm going to use the old beetle system but have the 2 sides welded together so there's total stiffness in roll - means I can easy take a crank to a "spine" mounted spring/damper and the tie rod can be a single peice affair with no possibility of tracking errors. I'll get pictures up eventually....
Not got very far yet...
