forcefed86
Established
- Joined
- Jul 31, 2022
- Messages
- 89
I am very familiar with the boost function. Use it on all my bikes. Just upgraded my ND96850 with working boost for an ND961000. This apprears to be a gen2 controller as all the pin outs were different. And the pin6 (brown wire) is for a display, not boost as it is with the GEN1 controller.
So remap the cruise pin (pin 17) to boost as I've read is the correct method. This does not activate boost. I tested this with pin 8 and pin 17. Both remapped to boost. Neither work for boost. Both tested and confrimed to work as reverse and cruise functions. I made sure no other pins are assigned to the same pin as boost. Its like no settings changes made in the advances section of the phone application to pins hold. Only when you identify on the simple screen do pin changes take? But there is no boost function on tha tpage so I can't assign the pin. Has anyone got this to work?
I do have the boost settings all setup correctly. 20sec boost 30 sec cool down. Main line amps is 2a and boost is 20a (for testing only). Grounding the pin assigned to boost never activates boost on the APP. What is the issue here? Can you assist?
Thank you!
Thank you!
