icecube57
Ok im getting my chops busted for doing this. Apparently its hog wash but I have some 6s 8AH Zippys that are little over a year old. Varying states of abuse. Some I ran at 3s 1p for a while with a 65A Lyen 3077 Mosfet controller and when I got my bike setup I ran 3s 3P in a Falcon EV Frame bag. About 100+ or so cycles and varying DOD but roughly probably 25 discharges at 100% 75% 50% and 25%.
I recently did discharge tests on my packs to get a feel on how they were aging and check capacity.I had 4 packs that were giving around 7AH and the others were 7400-7500mah. When they were fresh they were all about 7800-7900 at .5C 4A discharge. Ive never been able to get full AH out of these packs at 1C nor at .5C they came close. They only delivered at .25C or lower so IR i think is a factor with these batteries.
So I have a few that are a little fluffy not OMG throw it away bloated. Guess which ones.. the ones that were the lowest capacity. When I discharged them I didnt charge them back up. When packs are discharge the shrink and get squishy a bit. However these packs still are a little bit swollen. I put the packs in the fridge and the felt a bit more solid and they had gone down in size. I went to the store and got some filament tape and took the packs out of the fridge. Waited for them to return to room temp and start putting rows of tap around the pack very tightly. I went length and width wise. I put the pack back on the charger.
I have an Icharger 406 Duo by the way. Its hard for me to mess this up.
The pack originally gave 6915AH on the first discharge. 4A Discharge
After wrapping I put back 7414AH into the pack (8A Charge Slow Balance)
One the second discharge test I got 7218AH out of the pack. 4A Discharge
On the charge up I put back 7519AH.(8A Charge Slow Balance)
I will do one more discharge to see if there is any improvement or if it stays the same.
Im also going to check the pack that didnt have any physical deformities. This was one of the better packs that delivered 7445AH on first discharge. I wrapped it the same way as the swollen pack and will charge it back up and discharge it again to see if there is any gain if any.
The packs do seem much harder and not due to the tape.
Your thoughts
Your thoughts
