EddySPalm
- Slowly working on the controller/DCDC converter/ throttle compartment. Bought and installed nut inserts for fastening the controller with machine screws. As I want to be able to unscrew the controller and I will not have access to the two rear screws, I will make up two brackets for it to slide into in the rear, and just use screws in the front where I can access the screws with a ratchet.
- Charger came in. I landed on a Supower 8A version. I wanted to go bigger initially, but 15A's and up are so huge that it wouldn't fit where I plan to fit it. Now to find some neat solution to mount it inside the opposite (left) bubble in the chassis, both free from contamination and still let it breathe like it should.
