mrzed
Hi all. Got my toolpack batteries from doc all pulled apart, and my hyperion 1420i charger arrived yesterday. My holiday project will be to turn this pile of bits into a 14s/as many as I can-P pack.
First - for the charger, I'm planning on using a deep cycle 12v RV battery for starters because I have one. Can I leave the battery attached to a 12v charger/maintainer while I attach the hyperion to the battery? Tried to google this, without success.
Second - for the balance leads, I'm planning on using 2x7s balance taps because the charger supports this (why I picked this model). Are there places I can purchase prewired 7s connectors that are long enough so I can just solder the loose end but not have to fuss with crimping all those little wires? Should I go with JST-xh standard? Charger also supports the hyperion standard but that appears less common.
Third -for the wiring of the balance leads, does the 8th wire on each connector terminate on the same place and measure the full pack voltage? I kind of assumed this, but could only find lipo balance wiring diagrams for single connectors - none that show multiple balance connectors on a pack.
