CSN
- Joined
- Mar 4, 2015
- Messages
- 154
So this is my $20 mounting and enclosure solution. Can get the 3" inch ABS pipe(about 5mm thick) and alum corner molding at any Home Depot etc.
I am using some threaded inserts screwed into the alum frame. The ABS has a hole drilled for a bolt to screw into the insert. Min 2 and maybe 3 knurled 8-32 screws to connect to the frame.
http://www.afi.cc/contentonly.aspx?file=images/vendors/EZLOK.pdf
I thought about magnets to hold the enclosure but have my doubts.
To cut the ABS I used a Rotozip to slice it. I clamped the tube down to a bench and just slid the rotozip along the counter and easy straight cut. Can shim it up or down for more or less room inside. I went a little past halfway.
Used a power hack saw with finer blade to cut notch in ABS and Alum frame. Drilled holes in the alum for truck bolts.
37 inch Jet Pilot deck
DIYelectric single paris mount
5065 200kv motor
TB's 12s ESC
15/44 gearing
LED push switch mounted of deck.
2 x 4s = 8s zippy flightmax 5ah x 2
Wiiceiver and Nunchuk. Drop free if a rubber band is holding the dongle down tight.
Ekick light
90mm Big Foot Abec clones
Any tips to refine it? I ordered some knurled thumbscrews for holding the enclosure.
Also will definitely find higher quality rubber bands etc.
Currently weighs just a tick over 15 pounds.. 16.8 kg.
If mounted well it would make a good grind surface and cheap and easy to replace.
