This is the first eboard I have ever built.
I plan on using a clunky ebay board with very little flex, an 120a 6s esc, and a single 6s 5000mAh batter pack (Although I may buy another battery if my board will be under-powered)
The list of parts that I have ordered is below. I was on a budget so I bought the minimum parts that I thought I needed and so far I have only spent ~$470.
Board http://www.ebay.com/itm/Longboard-Downhill-top-mount-quality-skateboard-blank-10-125-x-39-DH-gripped-/252170703190?hash=item3ab68b9156:g:BdQAAOSwHnFVr-82
Esc http://www.rcjuice.com/fvt-120a-brushless-sensored-sensorless-car-esc-2-6s/
Battery http://www.hobbyking.com/hobbyking/store/__9176__Turnigy_5000mAh_6S_20C_Lipo_Pack.html
Reciever http://www.hobbyking.com/hobbyking/store/__44693__Quanum_2_4Ghz_3ch_Pistol_Grip_Tx_Rx_System.html
Trucks + motor http://www.carvonskates.com/store/p4/CarvON_V2_Single_Hub_Motor___Matching_Front_Truck___Wheels_Set._Available_T
rder_Now..html
I wanted hub motors because of the added sleekness and I found that belt driven setups usually cost more. I settled with a 120A esc after I was advised that I needed a bigger one, but CarVon (the guys who manufacture the hub motors) said that it was fine. I am concerned that the single 6s battery I bought will not be enough power for high speeds and longevity especially with the weight of the board. If it is not powerful enough, I can buy another battery and (probably) link it in parallel.
After I receive all of the parts, the next challenge is finding a way to mount them. I am curious to know how many people have attached or mounted their components to reduce shock. I would like to make it look as functional and neat as possible.
