One of the motors in that CL ad looks like the right one.
E-Glider said:So the Gen 2 doesn't like bumps in the road! Strange.. was that an isolated case or do they all apparently do it?
Sounds like a bad connection in the standard wiring might also cause the same thing?
Gwest said:Cheers: I’m in Redwoodcity but both my parents are from Aus. Sidney (Dad) Pamarada (Mom)
So it sounds like my best thing to do is go with a aftermarket controller & wheel.
I’m in need of some Help! Fletcher can you help me ? I could drop off the bike and pay you for your time and labor parts and what ever
E-Glider said:Guys, would I be right in thinking that the A2B Gen 2 wheel/hub would NOT need to be split, in order to hook it up to a generic external contoller - unlike the Gen 1 version?
If so, that might be the easiest option for you ~ at least then you'd 'only' be on a re-wiring mission, rather than a full hub strip-down too?
