Jethro56
I have a Trek 7300 Hybrid That I'm considering as a candidate for an ebike. What I would like to do is purchase a geared front hub 48V lipo system from e-bikekit.com. I've read where front aluminium forks are not a good idea to power. The suspended forks are Suntour NEX 4110 TK. The upper tubes are definitely steel. The cast lower portion has some magnetic properties but not enough to hold the magnet up.Will they standup with a torque arm?
If I go with a rear drive I would like to stay with the eight speed if deraileur adjustments are unnecessary. The reason for this would be for ease in going back to non ebike uses. Somehow I think this may be unavoidable as the necessary shims will move the deraileur out of alignment.
While I'm at it. I noticed most pictures of ebike conversions show full suspension mountain bikes as the donor. Is it because of speed or durability or availability?
Any comments would be greatly appreciated.
