John in CR
100 TW
The motorcycle I hacked up for parts had a floating sprocket at the wheel. I assume that's to counter flex in the frame under high load. Is that something we need to consider, or is a perfect chain alignment via an adjustable motor mount sufficient? Does it make a difference if the motor is mounted on the swingarm?
