[For Sale: €800] BeastsEnergy 51.2V 5KWh Rack-Mount Battery (Brand New A-Grade Cells)
Ella
🧲 New user
spamland
Hello!
I am a newcomer from China, exploring the international platform for the first time.
I might not be fully familiar with all the rules, so I welcome any feedback if there are any mistakes, and I will promptly correct them. Thank you very much!
I am looking to find a group of beta testers for our rack-mount battery.
To achieve this, we have decided to offer a 20% discount, making the total cost €800 each. The quantity available is 50 units.
This rack-mount battery utilizes brand-new A+ grade cells (REPT), a BMS from Topband, and boasts a waterproof rating of IP21. The warranty period extends for 10 years.
We have conducted extensive compatibility testing to ensure seamless integration with the majority of inverter brands available in the market.
The price of €800 requires the use of a discount code.
Technical Specifications of This Product:
Energy (Wh):5120 WH
Nominal Voltage:51.2V
Nominal Capacity:100Ah
Built-in Battery Cell:LiFeP04
Dimension (L x W x H): 580*440*160mm
Product Weight:55kg± 5kg
Max. Operating Current:100A
IR:≤100mΩ
Cycle Times:≥ 6000 cycles @80% DOD, 25°C, 0.5C
Design Life :≥10 Years
ChargeVoltage: 56V
Discharge Cut-off Voltage: 46V
Charge Temperature: 0°C~60°C
Discharge Temperature :-20°C~60°C
Storage Temperature :0~ 45°C@60%±25%RH
Certification: CE, ROHS, IEC62619,IEC62133, UN38.3,MSDS
Feel free to contact me if you're interested.
Thank you!
They are located here:
Which specific cell model does it use?
Can you link to the page on this site it is on, so we can access the specifications?
What does the warranty cover?
How does an owner get warranty service or parts?
That's quite a range of measurement, which usually indicates that each unit could be made of very different parts. Is there a reason for that?
What is the recommended (typical) operating current?
ChargeVoltage: 56V
Is the charger built into it?
If not, what is the charging current limit and/or recommendation?
Could you link to these certificates?
Ella : REPT 100AH
Ella: https://www.chinarept.com/upimage/affix/638239903992655063.pdf
Ella :provide free replacement of components to customers within 5 years. If the entire unit cannot be repaired, it will be replaced. Free technical support will be offered from the 6th to the 10th year.
Ella :We can send the components to ower and give video guidance or online supports
Ella : sorry . it is a typo. weight :46kgs
Ella : As long as it's below 100A, it's safe.
Ella : there is no charger into it . you may need a inverter , which can be a charger also can be able to convert direct current (DC) into alternating current (AC)
Ella : As long as it's below 50A, it's safe.
Ella : we are not going to link certificates so far , but can show them to customers before they buy it
