For the future Tangent drive? Bulk metallic glass..
Voltron
Santa Barbara CA
From space.com..
" The two new research papers focused on the use of bulk metallic glass (BMG) as a material for crafting gears for space-based missions. Metallic glass is called BMG when it is used to manufacture products larger than 0.04 inches (1 millimeter).
To make BMG, engineers first melt metal. Solid metals have a well-organized, crystalline atomic structure. But when the metal is melted, the atoms lose that structure and become randomly arranged, according to a statement from NASA. If the metal cools slowly, the atoms will go back to the crystalline arrangement. But if the liquid metal is cooled extremely rapidly — about 1,800 degrees Fahrenheit (1,000 degrees Celsius) per second — then the disorganized atomic structure remains. [Video: NASA Tests Robotic Refueling Tech]
These rapidly cooled metals are also known as amorphous metals, and "by virtue of being cooled so rapidly, the material is technically a glass. It can flow easily and be blow-molded when heated, just like windowpane glass," NASA scientists explained in the statement.
Metallic glass was first developed at the California Institute of Technology in the 1960s, and "has been used to manufacture everything from cell phones to golf clubs," NASA said in the statement. "
"One of the new papers, published in the journal Advanced Engineering Materials, shows that the gears demonstrate "strong torque" and smooth operation without lubricant at temperatures reaching minus 328 degrees Fahrenheit (minus 200 degrees Celsius)."
The interesting part..
"An example of a strain wave gear, also known as a harmonic drive — one of the most expensive types of gears used in high-precision robotics. As the gear turns, the flexible ring inside it squeezes, becoming an oval shape.
The gears' ability to function at very low temperatures is important for two reasons. First, some materials (including some metals) become brittle at cold temperatures, but that isn't the case with metallic glass.. That means there's less risk that a gear tooth will break during operations, according to the statement.
The second benefit has to do with power consumption. "Being able to operate gears at the low temperature of icy moons, like [Jupiter's] Europa, is a potential game changer for scientists," said R. Peter Dillon, a technologist and program manager in JPL's Materials Development and Manufacturing Technology Group. "Power no longer needs to be siphoned away from the science instruments for heating gearbox lubricant, which preserves precious battery power.
Other benefits of BMG gears may result from low cost and ease of manufacturing. Parts made from BMG can be cast using injection-molding technology, according to the NASA statement, which means the material is liquefied and injected into a mold. This technique is also used to manufacture plastic parts."
OTC: LQMT
I watched this stock back in 2002 when it was an IPO. This looks like what your post is describing. I know they made golf clubs and cell phone parts. In the end it was costly and very limited in production ease. It would seem the material needed to be cooled uniformly and thus items with thick and thin cross sections was problematic.
In 14 years I have not seen anything new.
Just sayin’…
Unless you plan to use the ebike at cryogenic temperatures I'm not sure what the possible advantage is?
