McDesign
I've been reading here, and it seems that a consistant problem with the small brushed motors is overheating.
I work with thermal management in my real life, so here's what I'm going to try. First, I'll put the motors in the airstream (on top of the front wheels, in this specific application) - but still, there's darned little surface area available for convective heat transfer to the ambient air - so how cheaply and best to add "extended surface" (radiator fins (though a car radiator doesn't really "radiate"; it's a heat exchanger))?
An axial fan might be nice, but it takes power to run, and its airflow is perpendicular to the nice cooling airflow from the motion of the moving vehicle
Not long ago, I learned to make signal lamp and fan shroud bezels with just a hammer - bend a long piece of ~1/2 X 1/2" angle from .060" aluminum, and keep hitting one flange as it lies on an anvil or a vice (I do have a shrinker and stretcher now, but they're just faster, not better)
So now, make some similar rings, and tie-wrap them to the motor (drill some clearance holes in the mounting foot for the tie-wraps to pass through), using some conductive grease between the steel motor case and the fins -
I think I may try one with and one without on the first trike, thermocouple both, and see what surface temp differences I see.
Forrest
Forrest
