PRW said:No, no teeth inside. Thanks guys.
thanks dogman dan, I didn't realise...dogman dan said:Possible to use a regular freewheel removal tool once you pull the cover off the motor. with the axle out of the way, you don't need the tool with a big hole for the fat axle.
wow - good eyes - didn't spot that. Thanks!nutspecial said:That last pic. Shows the 1.37" threaded base attaching fw body to the hub motor- and also the 'teeth' for removal?
PRW said:thanks Ykick - yes, there is a lock-ring. Counterclockwise will be the answer - I will do that when I get home!Ykick said:That looks like a cassette to my old eyes. Try gently tapping what looks like a lock-ring counterclockwise.
No problem - I will try with with a freewheel tool first - one is on order.Ykick said:PRW said:thanks Ykick - yes, there is a lock-ring. Counterclockwise will be the answer - I will do that when I get home!Ykick said:That looks like a cassette to my old eyes. Try gently tapping what looks like a lock-ring counterclockwise.
Not so quick, I hadn't seen that picture and I can see splines deep inside. The lockring may be to disassemble the freewheel?
Ykick said:What motor is this? Looks kinda small for DD. Geared hub motors I've had apart use 2 piece axles.
As mentioned, you may be able to remove the cover with the freewheel?
PRW said:bought a new side cover from EM3EV, rather than trying to sort out a new bearing. Such quick service.
Photos show the original bearing just disappeared - no sign on it, other then some shards of metal
