Supertux1
Hi all,
So what has anyone done for mounting batteries on the handlebars or front forks?
I'm trying to figure out what options I have for a ping 48v 15Ah running a rear wheel direct drive that don't involve a panier and making it tail heavy.
I know that putting it in the triangle frame is usually the preferred way to go, but that tends to exclude the use of full suspension bikes.
Is it even possible to have a large battery, balanced bike and full suspension given these limitations? Seems like you can choose two out of three here.
I've seen pictures with Pelican boxes clamped to dual crown forks, but those tend to be extremely expensive and really only an option on gravity bikes.
I've seen other builds where the boxes were attached to the handlebars with some kind of clamping system, I think I might want to do this.
I've seen some where a front rack is used as well, but aren't good at carrying loads without breakage / vibrations. (weaker alloy forks etc...)
So what do you think, are there any good 'basket' type solutions and what are their drawbacks?
