DryMycologist6432
🧲 New user
Hey all,
I'm building a teleoperated 4WD patrol buggy as a personal project and hit a wall with the front-end stability. Hoping to crowdsource some "what would you do differently" wisdom before I start cutting more metal.
Build specs:
- ~150 lbs fully loaded (frame, 4x hub motors, batteries, electronics)
- Chassis is 4040 aluminum extrusion
- 4x brushless hub motors (one per wheel), ~20" wheels
- Wagon-style front pivot steering
- Linear actuator drives the pivot
- Pivot bearing is currently a lazy susan between two aluminum plates, bolted into the 4040 extrusion with T-nuts and through-bolts
- Runs on mixed terrain (pavement, grass, gravel) at low speeds (~5 mph)
- Tooling constraint: I only have a pillar drill and a miter saw. Would prefer solutions that work with off-the-shelf parts + aluminum extrusion.
The front end wobbles badly. I've narrowed it down to a few behaviors:
- FWD is the worst, RWD is slightly better. When I drive with only the front hub motors, the pivot plate visibly twists under load. Every bit of motor torque tries to rip the pivot sideways instead of propelling the vehicle. It genuinely looks like the bracket is going to snap.
- The whole front subframe has some flex in addition to the pivot itself, I can see and hear the rectangular extrusion cage skew slightly under hard turns.
- Are there any quick fixes to drastically reduce the front-end bend that stay within my tooling constraints (pillar drill + miter saw, aluminum extrusion, off-the-shelf parts)?
- Is this rabbit hole of improving the pivot worth going down, or should I switch to Ackermann steering? If so, what's an easy way to do that with this frame?
Appreciate any and all takes, especially unsolicited roasts of the design choices.
Thanks!
