2wayspeaker
- Joined
- May 24, 2015
- Messages
- 31
Hello, I'm new to the forum and Eboards.
I'm a student design engineer, so I know how to calculate, design and build stuff.
However I lack experience in both sateboarding and quadcopters.
I want to design a portable Eboard, under 4kg shorter than 60cm.
First I'd like to welcome any remarks on my choice of components:
Second some questions:
1. Can I design the board to be front wheel drive on a single wheel? What are the benefits/problems having a front wheel drive vs rear wheel drive?
2. When I charge the board should I shut off the ESC, and vice versa? I know the batteries usually do not stay in the circuit while charging. The Charger usually also doesnt stay in the circuit whilest driving. Is this a problem if I would or should i provide a switch (Drive, OFF, Charge).
3. I can simply use the SBEC output of the ESC to charge my phone (5VDC), right? or does this cause any problems?
Thanks alot for reading this!
- Logic 3 Nunchuck
- Arduino mini
- 6S 5000mAh
- 63mm 1700W (@6S) 230KV Outrunner
- 120A ESC
- 265mm 5MHP belt 15mm
- 16T Pulley
- 30T Pulley
- 6S Balance charger and step down integrated as to charge with 120W laptop charger
- 184mm trucks
- 70mm 78A wheels
- Custom Glass Fibre/Aluminium honeycomb Board integrated components (Still designing)
