Hey there, about to make my first build and I wanted to get some input on these parts before I order:
A 6R25M054090 5 mm (HTD) Pitch, 54 Teeth, 9mm wide Single Sided Neoprene Belt with Fiberglass Cords
A 6L25-040SF0910 5 mm (HTD) Pitch,40 Teeth, 0.313" Bore, No Insert, Polycarbonate Timing Pulley for .354( 9mm )" Wide Belt
A 6A25M014DF0906 5 mm (HTD) Pitch,14 Teeth, 6mm Bore, 2 Flanges/With Hub, Aluminum Alloy Timing Pulley for 9mm Wide Belt
Will this work with a Turnigy 260KV SK3 Motor with 8mm shaft? I know I'll have to bore the pulley hole from 6mm to 8mm and probably flatten out a part of the motor shaft but I'm a bit confused as to how to tighten the pulley on to the motor shaft? Does it have a grub screw on it?
For the mount, can I use a Bridgeport CNC to make the mount? I have never machined anything before, is it easy enough that with a few YouTube videos a noob can do it?
Thanks, and I promise to post pics along the way
