Hummina Shadeeba
http://www.ebay.com/itm/Orangatang-Kegel-Electric-Skateboard-Pulley-Kit-/231522358955?pt=LH_DefaultDomain_0&hash=item35e7ced6ab
I bought one.
anyone ever use it or have any knowledge about abs or this one in particular?
it says:
1x ABS 36 tooth 5mm HTD wheel side pulley
1x Aluminium 16 tooth, 2 flange, 6mm bore size, 5mm HTD, drive side pulley
1x 5mm HTD pulley, 59 groove, 9mm width and 256mm pitch length
it seems to come with both pulleys and I think the belt but the belt says 9mm and I'm confused.
PLease tell me again where or what's the formula for finding the belt length with two known pulley sizes and distance between them. I never remember long enough to finish this process
I wont use the drive pulley that comes with this since it's 6mm and I need 8mm. Do you think I'll be under-geared with a 36x a 24 tooth? with a tacon 160 63mm motor at 245kv with 30volts? I do have hills and am finding I'm not the speed demon I thought I might be and my board is creepy at above 20mph. If I convert it to wye and get it to 170kv would that be better?
I bought one.
it says:
