there was a post on how to add a 12 booster battery for temporary added power and speed. by running a 12 volt SLA battery in series with the 36v lithium battery. This is the diagram they posted ( I added instead of one 12 volt battery, to add two 12 volt batteries in parallel, in series with the 36 volt battery. Will this work?? what other electronics are needed to make this work. I am not sure if this is a do-able circuity or safe. Lookng for feedback from masters at ES.
Seems to me that a voltmeter in parallel with the 12v booster battery would gradually discharge the battery, even while the boost function was not in use, if the boost button was in the on position??
I am wondering if this setup could also be used as a way to have a battery backup or reserve power.. Say, for example the person uses 60 or 80 percent of the capacity of thier 36v battery. And it is not coming close to to triggering LVC of the BMS.. the person flips the switch that adds the additional 12v 7ah batter in series.. What would happen? what voltage would the system have? how many ah of capacity would it have? What would happen to the batteries?
"A 36V 16Ah battery in series with a 12V 7Ah battery would give 48V, but your usable capacity would be limited by the 7Ah battery.
The smaller capacity battery would obviously become discharged much sooner than the larger one, and if there is no battery protection on the lower capacity pack, it will soon become damaged simply by allowing its voltage to fall too low, and also by the larger capacity battery trying to reverse charge it when it becomes so depleted that it can no longer supply the current being consumed by the motor.
A smaller capacity battery could be used as a temporary power boosting feature as shown here:
It would be a good idea to have some sort of audible battery warning device (or perhaps a voltmeter) connected in parallel with the relay, to automatically allow monitoring of the 12V battery, but only while it is actually being used.
If wired this way, the monitoring device would not gradually discharge the 12V battery while the boost function was not in use."
