StCroixSpeed
100 µW
- Joined
- Dec 31, 2016
- Messages
- 7
Hello,
I am a new eBike builder that recently completed my first system install. Having an issue with the controller intermittently switching from "sensored" mode to "un-sensored" mode (no hall sensor).
The drive system is entirely from Grin Technologies, purchased in late 2016:
35A Grin Sine wave controller
TCDM Direct Drive Hub motor with internal geared hub
12 magnet Grin PAS sensor
Cycle Analyst 3.1
Battery: Em3EV 50V 27AH 30Q battery
Bike: Surly Puglsey
During my first shakedown ride, I rode on a gravel road that had several pot holes. While I rode fairly slowly, the bike did get bounced around a bit. After this road, I noticed the more irregular operation and noticed the light on the controller blinking red, indicating a switch to un-sensored operation.
Typically when I turn on the controller the Hall sensors are active. Then as I ride down the road I will see my Speedometer reading go to zero "0", and the controller is blinking again. During a ride the system will switch back and forth between sensored/un-sensored mode sometimes several times in a 5 minute ride. The sensored mode is much smoother as one would expect.
I tried checking the voltage at the hall wiring connector but as soon as I start sticking the test meter into the connector the unit switches back to sensored operation.
For the experts on this forum which of the following areas are the highest potential to resolve the issue:
1. The Hall sensor connector
2. The Grin Sine wave controller
3. The Hall sensors in the TCDM Motor
Thank you for any and all suggestions.
Patrick R. McKellips
Cycle Analyst 3.1
Bike: Surly Puglsey
